SL55/63/65/R230 AMG: Advice
Old Mar 25, 2018 | 08:16 AM
Warrendog22's Avatar
Not yet
Advice
Considering a 2007 sl 55 with 85000 miles. Anything to start worrying about? NEW TO THE BRAND
Old Mar 25, 2018 | 08:30 AM
FxFormat's Avatar
SL 600
ABC ABC ABC ABC ABC ABC
At that mileage, either you get lucky and someone has overhauled all the lines/pump/accumulators, or you're getting someone's problems. Take it to a dealer to do a pre purchase inspection.
Old Mar 25, 2018 | 10:28 AM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
you have to take it to a dealer and get a complete cpo inspection, read the complete master dealer inquiry, and carfax
Old Mar 25, 2018 | 03:13 PM
57staff's Avatar
2008 CL550
I just bought an '03 with 56k miles. Things that came up on my PPI include front bushings and ball joints, engine mounts starting to go, cracked and leaking rear 3rd brake light, trunk soft close not working. My ABC came out good - previous owner had replaced a couple of valve blocks and had a current fluid flush.
I already replaced the trunk struts and will be tackling the soft close lock and 3rd brake light next.
As far as the car itself is concerned, it is absolutely wonderful. More power than I know what to do with (and I'm going to get a tune for it), comfortable, easy to drive - everything I want in a GT car.
Old Mar 25, 2018 | 04:04 PM
skylolow's Avatar
2005 SL55 Completely Built Motor
Engine and tranny wise they are pretty strong. But you almost have to do a PPI and I'd have it done MB shop or very well trusted independent shop that works on a lot of MB. It might be the best $150 to $200 you ever spend.
Like everyone said ABC the number one thing. PPI should point you to any current issues with it. Repairs with the ABC can run from cheap DIY work to thousands and thousands of dollars. In many cases the later.
With that age you have normal wear items that should be looked like the bushings and ball joints, motor mounts, brakes, etc. All things a good PPI can alert you to.
