SL55/63/65/R230 AMG: Loss of power on the move!
Old Jun 10, 2018 | 11:21 AM
KAROZZA's Avatar
SL55 AMG/C180 K
2003 SL55 AMG
When hammering along by means of prodding the accelerator pedal on spirited drives, I get moments of loss of power. I keep moving along but pressing the pedal doesn't provide acceleration, then suddenly, back to normal. Sounds like TPS failure; right? Well that's a fault I got on STAR, so bought a new accelerator pedal(actually first bought a used one), but still get the failure!
Will be taking it back on STAR. Really need help on this.
Any suggestions?
Old Jun 11, 2018 | 10:31 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Originally Posted by KAROZZA
2003 SL55 AMG
Any suggestions?
TPS is likely a Throttle issue (often re-seating the cable at the Throttle body can fix this). also, could be a "bypass throttle" failure
probably worth confirming that the inter-cooler pump is functioning properly as well.
Old Jun 11, 2018 | 12:28 PM
KAROZZA's Avatar
SL55 AMG/C180 K
Spot on.
Hooked up STAR & according to my INDY, the inter-cooler pump is not functioning properly as he is getting high temperature readings. He also states he's done quite a few of these.
Now have to find part number & where best to buy; should this best be a Mercedes Genuine part!?
Appreciate your input.
Old Jun 11, 2018 | 12:33 PM
Spot on.
buy the bosch 010 pump. it is the upgraded factory pump (same part number as stock, last three digits are 010) you can find it online for $100 or so shipped
https://www.fcpeuro.com/products/mer...caAjYfEALw_wcB
Old Jun 11, 2018 | 01:12 PM
KAROZZA's Avatar
SL55 AMG/C180 K
Cheers for that! Will try to find it in Europe as I'm in Malta.
Old Jun 11, 2018 | 01:20 PM
just google
"0392022010"
and you should find a local seller (there are many ebay sellers that offer them new in the box for a competitive price).
Cheers,
Chris
Old Jun 11, 2018 | 01:27 PM
KAROZZA's Avatar
SL55 AMG/C180 K
Yes, found it in the UK for £108 + delivery.
Was quoted an estimate by Indy around €300!
