SL55/63/65/R230 AMG: SL55 AMG Base Dyno Results
Old Mar 13, 2019 | 06:54 AM
smithwn55's Avatar
SL 55 AMG, BMW M Roadster, Holden Commodore SSV
Took the SL to my LS3 tuner in NASCAR land (Mooresville NC) as I knew I could get a legitimate set of pulls done to establish a baseline. The owner, Alvin, is somewhat of a legend in the Charlotte area for his tuning expertise. If you have a car with an LSx engine, this is the guy to see.
It was low 40's with a neg 476 DA and I was pleasantly surprised at the numbers the 55 put down. Although differences in dyno readings between stock readings and mods is the all important metric, it seems evident that MB is pretty conservative in rating their engines.
Even though the car went in dyno mode easily, the tech had trouble keeping the car in 4th gear as it wanted to downshift. This resulted in him have to roll in on the throttle, somewhat affecting the slope of the curves. Anyway, the numbers speak for themselves, 445HP and 503Lb Ft TQ bone stock is stout to say the least.
For reference, my LS3 measured 397 HP and 398 LB Ft TQ after headers, a CAI and a custom dyno tune. My LS3 results are right in line with many others who own the same generation engine on the same Holden platform so I trust the dyno and the operators.
Not sure if the files loaded. If they didn't, somebody tell me how to do it (I dragged and dropped them) and I'll try again.
Bill
File Type: pdf
File Type: pdf
Old Mar 13, 2019 | 08:02 AM
Nor Cal SL55's Avatar
2012 E63 AMG
Nice! What year is your SL55? I'm assuming that those are rear wheel numbers.
Are you now planning on doing mods? Let the fun begin!
Old Mar 13, 2019 | 08:15 AM
smithwn55's Avatar
It's an 08 and yes, that's WHP as measured on a chassis dyno.
I will be methodically modding the car. First up will be MBH headers and a Quaife LSD. Will likely happen before end of year depending on funds available. Following that a tune, a smaller pulley and more cooling. All in should get me another 85+WHP plus more TQ. Can't wait!
Bill
Old Mar 13, 2019 | 10:13 AM
57staff's Avatar
2008 CL550
Looking at your charts, does this mean the stock redline for our engines is 5700 RPM? I've always wondered how hard I can push my engine.
Old Mar 13, 2019 | 04:12 PM
smithwn55's Avatar
Good question.
The cars red line is 6100 rpm according to my understanding. For whatever reason, the tech chose not to take it that far, probably because little extra HP would be generated vs. the stress on the engine.
Bill
Old Mar 13, 2019 | 10:53 PM
2012 E63 AMG
I think in 4 gear - 155 hits about at this RPM and governor kicks in
Old Mar 14, 2019 | 10:23 AM
57staff's Avatar
2008 CL550
Unless you've had a tune that removes the speed limiter
Old Mar 20, 2019 | 01:10 PM
2012 E63 AMG
Some dynos are also limited to 250 km/h or 155 mph.
Old Mar 27, 2019 | 04:56 AM
Woodpecker1's Avatar
2003 Mercedes SL55
So how much did they charge and what is the name of the shop because I would like to have my SL dynode as well I'm only an hour and 20 minutes from mooresville
Old Mar 27, 2019 | 07:04 AM
smithwn55's Avatar
$75 for 3 pulls, takes about an hour. You need to schedule it. Call and speak with Mark or Kelly. Shop name is PCM of North Carolina. Tell um I sent you.
Bill
Old Apr 4, 2019 | 11:09 AM
AMG_55_cruiser's Avatar
2004 CL55, 2003 SL55, 2017 S63 Cabrio and 2009 G55
Anyone know what if any impact it would have on results not putting in dyno mode? I had my car Dyno’d yesterday and completely forgot to ask him to do that...doohhh
Ran into same issue hitting limiter in 4th so pills were done in 3rd.
Just wanted some baseline numbers before do pulley and tune.
Old Apr 4, 2019 | 03:16 PM
smithwn55's Avatar
I read that it disables ABS, Traction Control, Power Steering and Stability Control
Old Apr 6, 2019 | 06:16 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Those are good numbers on a stock car. Most are in the 410 to 430 range. Now for phase 2, start adding mods
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 6, 2019 | 08:44 PM
Thanks. Did SC pulley and tune today. What a PIA getting SC pulley off. Total press fit. Had to fab puller and installer to do.
Old Apr 7, 2019 | 06:54 AM
smithwn55's Avatar
Yes, they are extremely solid for a stock SL55. And valid given my previous experiences with the shop and comparisons of its' work to other engine dyno results for the same motor/platform.
Old Apr 23, 2019 | 11:01 PM
Ingenere's Avatar
2003 SL55 AMG, 1989 348 Challenge, 1987 Testarossa, 1992 F40, 1989 Mondial t cab, 2001 X5 4.4 Sport
Speed limiter? What speed limiter?
I own a tuning company and we removed mine the first week I had the car back in '03 (and gave it a few more hp/tq). Our cars are good for 202mph.
Old Sep 1, 2020 | 04:13 PM
smithwn55's Avatar
Actually MB states the 2007 and 2008 SL55 models can theoritically achieve 208mph. A delimited 2002 Model was clocked at 202mph at Nardo Test Track in Italy in Dec 2001.
