Hi I own an SL55 and I have a slight issue. When I recently collected my car from the garage after a regular service, I noticed the car was in the high suspension setting. Apparently they put it in that mode to get it on and off the ramp. Didn’t think anything of it, put it back on the low setting and drove home. On arrival everything seemed fine. I parked up and left the car. On returning to the car I noticed the front nearside suspension was in the high position! I started the engine went through the settings no problem and set it back to low which it did, but every time I turn it off the nsf raises to the high setting? Any ideas why and how this can be sorted? It does have the lowering links as the only suspension modification just to let you know. Any help or advice would be gratefully received. Regards.
Currently Active Users (1)
