SL55/63/65/R230 AMG: Camshaft position sensor
Old May 21, 2019 | 09:30 PM
Firstclasstranz's Avatar
Slk55/s65
Hey all ... I’m going nuts here my car went dead with popular crankshaft position failure now it’s telling me camshaft position failure and I can’t for the life of me figure out how to get the damn thing out !! lol the crank was easy but there is two lines and a pulley in the way of the camshaft senor and I know there had to be a trick to get that bolt out but can’t find anything online any help would be greatly appreciated thanks in advance ..
Old May 22, 2019 | 11:39 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I'm certain that no competently-engineered scan tool is telling you that your camshaft position sensor has failed. I presume the engine management controller software has set a code because it isn't receiving a proper signal from the position sensor, and this could be due to faulty controller hardware, wiring, or a stretched timing chain as well as the sensor.
Old Jul 1, 2021 | 11:19 PM
skullbox15's Avatar
2014 C63
Thanks for sharing this
Old Jul 2, 2021 | 07:02 AM
chassis's Avatar
2017 GLE350 4MATIC
Pull the cam pos sensor connectors off and check for presence of oil. Common on 201x era MBs.
Old Apr 13, 2023 | 11:05 AM
James115's Avatar
C63 Amg
After the headbolts job and after i replaced the lockplates in the phasers, i 'mgetting the error P0019, the dealer where i took the car said that can be the phasers, i exchanged the position sensor left to right
and the error still persist, so it is not the sensor, i do not see any reason to think is the solenoid nor the timing chain,
Any suggestion before i dismantle the 2 exhaust camshafts and exchange the phasers to see if the error switches to the right bank?
Old Apr 13, 2023 | 12:55 PM
chassis's Avatar
2017 GLE350 4MATIC
Check the cam magnets (solenoids).
Old Apr 13, 2023 | 12:57 PM
James115's Avatar
C63 Amg
ok i was thinking to swap the left with the right and see what happens
