SL55/63/65/R230 AMG: SL65 Roof issue - fuse for sensor?
Old Jul 11, 2019 | 08:57 PM
carlsturm's Avatar
Issue: Convertible top won't raise with this error message "close trunk lid". I've confirmed my trunk lid (inside lid) is shut and secured completely) This issue started immediately after I pulled, inspected and re-seated several audio fuses from the rear fuse box located behind the passenger-side seat underneath the lid. (e.g., 54, 66...)
Coincidental with this issue is that my trunk lid will no longer open with my key remote even though key remote unlocks doors etc. I had to use the physical key to open truck and confirm inside trunk lid is secured.
Does anyone know if there is a fuse associated with the trunk lid sensor and which one it is?
Does anyone know if simply pulling a fuse and robbing power from a device would cause this issue?
BTW, I had my convertible top down while messing with the fuses and it closed without apparent issue
thanks in advance for your ideas
Old Jul 12, 2019 | 09:11 AM
Nor Cal SL55's Avatar
2012 E63 AMG
It could be that the catch cover in the trunk is not in the closed position? cover sensor not connected?
Other possibilities could be the fuses you R&R'd or could simply be the latch mechanism needs replacing.
I would check all the fuses and electrical connections first.
Old Jul 12, 2019 | 09:45 AM
carlsturm's Avatar
I'm going to check the fuses today and determine whether I inserted a fuse into a wrong vacant socket. Dumb error, but I've made errors before
I noticed last night that trunk does not open with the trunk switch on the door either. I'm thinking these multiple issues are connected. Thx for reply.
Old Aug 3, 2019 | 04:45 PM
carlsturm's Avatar
my solution...
Reporting back my solution was to pull and reinsert fuse = F71 (Pneumatic System Equipment pump) in rear fuse and relay box which is located behind passenger seat. I believe the PSE pump operates the trunk open/close which explains why I received the "close trunk lid" error message at dash.
Fixed just in time - Not a lot of Michigan summer days left
Old Jan 15, 2023 | 04:23 PM
sevensamurai's Avatar
2008 SL55, 2017 SL63, 2007 E63 Wagon
Thanks for this bit of information. Years later it was a HUGE help to me.
