SL55/63/65/R230 AMG: 2004 SL55 AMG "Electric Consumers Offline"
Old Aug 7, 2019 | 08:48 PM
LandSeaAir's Avatar
2008 W204
Is there a common consensus on what can cause this message/error? The car does this whenever I start it, then after driving/idling for about 20 minutes I get the "Electric Consumers Back Online" message and the top can finally go down, heated seats finally work etc.
I have replaced the battery and keep the car on a maintainer....yet even doing this the car has to run for a while before it allows all electric consumers to operate.
Old Aug 8, 2019 | 10:01 AM
Nor Cal SL55's Avatar
2012 E63 AMG
Your rear consumer battery in the trunk is dying. It has nothing to do with the starter battery under the hood up front.
Old Aug 13, 2019 | 07:36 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
You need to replace the rear battery. Your dealer parts department probably has one in stock. It is an easy swap.
Old Sep 5, 2019 | 01:56 PM
jdgun's Avatar
Looking
I get this from time to time, when my rear battery is low on power. all is well after a 20 minute drive as you mentioned...
Old Nov 18, 2019 | 09:02 PM
Creoleiii's Avatar
2004 AMG SL55
Two new batteries
I just purchased car three weeks ago. I put two brand new batteries in. The consumer battery (trunk) is an AGM type which in my opinion are superior
I get consumers off line for about two minutes first start every day. I always plug tender in overnight.
I don’t know if this is normal.
Old Nov 18, 2019 | 10:03 PM
mikeyssl's Avatar
2006 SL55
I had this issue earlier this year, same symptoms.
Turns out I needed to replace my alternator. Smelt like burnt plastic under the hood.
I was driving and I lost power to the SBC.. very scary! Lucky I was in traffic and exited quick!
You might be lucky and just replace the voltage piece.
Old Nov 19, 2019 | 10:10 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
That is abnormal.
Measure the voltage on the rear battery cables just before you start the engine. If it is above twelve volts, then the vehicle power supply module is suspect. If it is below, then the voltage regulator on the alternator is suspect.
Old Nov 20, 2019 | 11:18 AM
David Bynum's Avatar
2003 SL55 AMG
Originally Posted by bobterry99
That is abnormal.
Where is the power supply module, i have the same issue and measured 12.45 V at the battery in the trunk, I took also measured the voltage while it was running at 14.3 V. seems like good voltage but i didnt know about the Power Supply Module.
Old Nov 21, 2019 | 10:58 AM
bobterry99's Avatar
The power supply module is located in the left side of the trunk. It is mounted on the inside of the wheel well in front of the battery. You can not access the module without removing part of the trunk lining.
I would use Star Diagnosis or other diagnostic device to see what voltage the module is reading on "circuit 30".
