SL55/63/65/R230 AMG: Resonator Delete Pipe info Needed
Old Feb 29, 2020 | 12:28 PM
70K951's Avatar
2003 SL55, 1987 944 Turbo
What length of 3" SS pipe is needed to replace the resonators?
I found this on Ebay.
It says that it is 8", however it has got be longer than that if the OD of the pipe is 3".
https://www.ebay.com/itm/3-409-SS-45...0AAOSw-zVdcWKX
Mike
Just acquired 2003 SL55
Old Feb 29, 2020 | 12:38 PM
E55Greasemonkey's Avatar
This place is a joke.
Factory pipe is an odd 2.75" diameter not 3". Frozenboost.com used to carry that size in stainless. The ends can be flared by your muffler shop to slide over the factory pipes.
Old Feb 29, 2020 | 02:12 PM
70K951's Avatar
Thanks for the response Greasemonk, the reason I referenced the 3" is because I seen numerous people using the 3" pipe that will slip over the factory pipe. I planned on welding them up myself on my lift.
Mike
Old Mar 1, 2020 | 12:23 PM
skylolow's Avatar
2005 SL55 Completely Built Motor
If your having hard time sourcing it a local muffler shop should do the delete for less $150 while you wait.
Old Mar 2, 2020 | 10:00 AM
70K951's Avatar
Understand, I still need to bring in the correct replacement pipes to the shop if I don't do it myself. I want to install mandrel bent tubing, not have a shop bend pipe. That is why I am looking for the pipe size and length.
Mike
Old Mar 2, 2020 | 12:06 PM
6444johnf's Avatar
SL55
I would like to know if there is someone who has made a proper mandrel bent retrofit pipe I can purchase?
