SL55/63/65/R230 AMG: Dashboard going crazy (visit workshop - multiple warnings-battery-ABC-SRS--trunk open
i just picked up a new to me 2004 SL55 in silver with the SL65 rims and just gorgeous. It was a 2 owner car with 69k miles and all stock and in immaculate condition and drives amazing (no CELs or codes)
I drove it home this weekend from Ohio where the seller was located to Chicago where I live and and it drove fantastic until about 2 hours into my drive when the dashboard lit up like crazy with just about every warning possible and the speedometer and tach were going crazy also, plus the ABC and ride height were going on and off by them selves and the trunk open snd roof open warnings were going off and on.
This happened several times on the drive as the dash would return to normal after about 3-4 mins of this and then go crazy 30 mins later.
I took a quick video of it here - the car drove totally fine during these episodes and I did pull over and shut off the car and shut the trunk firmly and things were fine for about 30 min and then it happened again.
Car didn’t show no CELs or codes coming up from this as far as my ODB tool showed.
here’s the video
https://youtu.be/NMidRz1Qutg
When I got home i checked the rear battery voltage and it was showing 25% so not sure that was a factor, but I put the rear battery on my Noco Genius 3500 trickle charger on the repair function and after 24 hours the rear battery went from 25% to 100%.
i’m not getting a chance to drive the car today to see if it maybe was the battery being low, but curious if any of you guys have ever seen this before?
previous owner said the car has been bulletproof and was driven by his 60 year old mother the past 8 years snd never had this issue.
Appreciate any thoughts thanks guys - here’s a few pics
here’s the video
very likely a voltage yes
when a module's voltage is too low, this happens
I've had the rear battery on my trickle charger and seems to have helped the rear battery. I drove the car today for about 45 mins on the high way and none of the "dashboard" errors occurred and the ABC and ride height functions are working totally normally now.
thanks all for the feedback and i'll continue to check the rear battery voltage and at this point may just buy a new one.
here’s the video
QUICK. Update - I’ve had the trunk battery on a trickle charger every night since I posted this and I’ve driven the car quite a bit and the issue has not come back.
Appears I had a weak battery and I’ll just go ahead and buy a new one at this point but really appreciate all you guys feedback here helping me sort this out!
Now I’m trying to sort out do I do a crank pulley or a supercharger pulley to start some basic mods
.Were you driving in the rain from Ohio by any chance? This sounds like a similar issue with a car that the front fuse box “SAM” lid wasn’t attached and properly locked. Water got in and did exactly what you described. The only time I have seen these issues is when the fuse boxes or SAM’s get moist or wet, and they will if the lid isn’t on correctly.
I haven’t had the crazy dash issue since that drive and just been keeping the rear battery on a trickle charger which holds the battery at 14.0 approx when it’s driven. I only manage to drive the car about every 10 days since it’s a 4th car and I’m in Chicago but try to get it out when it’s dry - when spring comes I’ll get a new battery which isn’t too expensive at about 200 bux.
https://www.mbpartscenter.com/oem-pa...IFJlc3VsdHM%3D
