SL55/63/65/R230 AMG: ABS Pump
Old Aug 14, 2021 | 02:54 PM
Bwollen's Avatar
SL63 ANG Acura MDX
Angry ABS Pump
My MB dealer told me I need a new ABS hydraulic pump, mine has failed at the tune o $4,200.00 plus tax. It a 2005 with 91,000 miles system has been working good up to two weeks ago.
Is there a place where on can get an overhauled exchange pump? I did that on my two forward struts and saved a few bucks.
Old Aug 15, 2021 | 02:49 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Do you mean "ABS" or "ABC" pump? If it is the ABS pump, it may be covered under the 25 year SBC warranty.
If not covered, (because it is not a "complete" failure of the SBC?) you should be able to buy a rebuilt SBC unit (with ABS pump) from Mercedes for less than $800
https://www.mbdirectparts.com/oem-pa...UtNWwtdjgtZ2Fz
however, If it is the ABC pump (tandem pump)
It appears you can buy it directly from Mercedes for $1050
HTH,
Chris
Old Aug 15, 2021 | 07:07 PM
Bwollen's Avatar
SL63 ANG Acura MDX
Sorry its the ABC pump and thanks for the info
Old Aug 15, 2021 | 07:58 PM
ItalianJoe1's Avatar
2003 CL 600
I bought a reman one off rockauto.com years ago for my car, spent less than $250 on the part, it still puts out 190 bar and passes a rodeo with flying colors. I believe it was an AC Delco reman. There are cheaper options out there than OEM, which are reman anyway at this point, don't let the dealer rip you off unnecessarily.
Old Apr 4, 2024 | 10:32 PM
arikinthecity's Avatar
2006 CL500
Tandem pump rebuild option
This vendor rebuild pumps. I have not used their product this is not any endorsement just into to help others
https://bzrebuilders.com
