SL55/63/65/R230 AMG: Rear trunk panel/fascia
Old Feb 26, 2022 | 11:51 AM
Tomcat SL's Avatar
2004 SL55 AMG
I had some work done on the folding top and the technician removed some panels (while I was not present). The work was incomplete (long story) but now I am trying to replace the panels. This is in reference to the furthest aft panel along the back of the trunk wall (nearest the latch/bumper/etc...).
In the attached pictures you will see that (when I was trying to re-assemble) I found a power plug that I had never noticed before (5 years of ownership :-(). I do not know if it was ever hot or not. It seems to be missing its "guts". I also found a plug that I don't know where it is supposed to go.
Due to location, I am assuming that the plug should go to the power socket BUT the socket has no where to attach the plug? Also, I'm a little concerned about leaving a plug (which seems to have some higher amp/gauge wires attached) floating around in the trunk.
Does anyone have experience:
1. Can you confirm this plug goes to this socket?
2. Is this an option (maybe it never had the "guts/inners"?
3. Are the "inners available" for a plug/play with the socket?
4. Is it "safe" to allow the plug to float around back there?
Old Feb 26, 2022 | 12:40 PM
cdk4219's Avatar
95 SL600
If I remember correctly I believe it plugs into the side of the power plug and that is definitely the plug for a socket like that
Old Feb 26, 2022 | 01:16 PM
Tomcat SL's Avatar
2004 SL55 AMG
So, I am missing the "guts" to the plug?
Still available?
Old Feb 26, 2022 | 02:28 PM
cdk4219's Avatar
95 SL600
Yea I am wrong, you appear to be missing something, tape up the end and put it back, more than likely you wilt ever use it.
Old Feb 27, 2022 | 09:31 AM
Tomcat SL's Avatar
2004 SL55 AMG
Can someone link me to getting the correct part #? I'm 30-45 minutes away from a Dealer
