Hatchet job complete!
Subscribe
Oct 13, 2022 | 01:28 PM
Finally got my cooling system split. Install wasn't too bad. Wish I would have bothered to remove the bottom tray and put a bucket to catch everything. Needed to get a 3 way T in addition to the union provided with my kit. I think this is because the SL already has an additional heat exchanger? Find out soon enough I guess. I got the expansion/overflow tank from Project B5. It seems to be of good quality. I had to "fab" that bracket, as I didn't see a nice spot to mount the thing.
Reply 0
Oct 13, 2022 | 03:50 PM
for the record, I did not want that vent port connected to the main cooling loop. for some reason I thought the factory bleed lines wouldn't be pressurized.
Reply 0
Oct 14, 2022 | 08:55 AM
Any measurable improvement in IATs? I was thinking of doing water/meth injection to lower IAT's for drag and half mile runs.
Reply 0
Oct 16, 2022 | 07:53 PM
Quote: Any measurable improvement in IATs? I was thinking of doing water/meth injection to lower IAT's for drag and half mile runs.
So this is far from exact.
75f ambient on the last day I logged. cruising IATs were 117f or so. they hit 127f @ 3k rpm w/ 10.4psi.
Since then I: replaced IAT sensor, divorced cooling system (duh), put a shorter belt on so less slip.
I
*should* be seeing like 13-14psi now. Ambient temp is 57f, and I peaked at 116f. Went from a stop to ~75 mph.
I'll need to do an actual datalog, the new results were just glancing at the live data on my scan tool.
Reply 0
Oct 17, 2022 | 07:36 AM
I was looking at IAT and boost data from drag racing I did last month and my IAT at start was 126 F. I don't recall exactly but I think ambient was around 70 to 75F. My system is stock but I did replace the circulation pump recently with Bosch unit.
IAT increases fast, up to 160F by the end of a quarter mile.
Reply 0
Oct 17, 2022 | 10:03 AM
yeah my temp at the start of the run was 86-89f, so splitting the cooling system does seem to have had a measurable effect.
I have an additional heat exchanger to get installed. I really need to get my front bumper off, I just hate dealing with body/trim panels so much.
Reply 0
Subscribe
Currently Active Users (1)
