SL55/63/65/R230 AMG: R230 SL65 Intermittent coolant leak help
Here is a video of the issue. I wasn't super thorough on the video unfortunately.
Anyway, I took it for a spin again and took off the covers and again no leak ... very weird.
The smaller pump on the right/passenger side is for the residual heat system - you can set the HVAC system to continue to run after the car is shut off in cold weather and this pump keeps the coolant recirculating through the heater core, extracting remaining coolant heat to warm the cabin.
The EPC page you want is Heating and Ventilation > Heating Water Connection. The part number for that pump is 230-835-03-64.
The intercooler pump looks similar in the catalog illustration and in photos of the part by itself, but in reality it's a lot bigger than the heater coolant recirculation pump.
I see you're in Houston. If you're ever in the Austin area, hit me up and I will buy you a drink ... cheers!
