SL55/63/65/R230 AMG: ABC Valve Block Overhaul Seals
I have done a few of these over the years & not many have been successful. My left front sags over around a week & the last time I did it, it improved as it used to sag after a few hours prior to overhaul. Strangely, if memory serves me right, I even switched over the locking valves in one overhaul, but the car still sags on the same side.
Would like to ask if any have been quite successful doing these & maybe which brand seal kits have been used? I have a couple of extra valve block so might try again as I'm thinking of replacing the large accumulators as preventative service.
Hope that helps,
Chris
Been quite a few years since I did it, but I seem to recall that I stretched them by hand (you could always do it carefully with some smooth-faced needle-nose pliers). I measured them before I started and then carefully stretched them until they were (IIRC) 20-25% longer (free length) .
Cheers,
Chris
Cheers,
Chris
