SL55/63/65/R230 AMG: Has anyone installed/purchased AMG door lock pins
It is a case of, remove the door panel, unscrew the plastic one, then screw the Chromium one into place, then replace the door panel.
If you repeat this operation on the other door, 'Presto' New door pins.
The actual problem is where to start with the door panel removal, and in what sequence to continue !
I ordered the AMG door lock pins to be installed at Affalterbach - when I have to visit them ( V-Max delimitation )
Part no: HWA1407600141 - "SICHERUNGSKNOPF" @ 35 Euros
installation = 35 Euros each.
total costs 140 Euros
IMPORTANT !! If you install this by yourself - do NOT forget to mark the position of the old pin ! Otherwise it will not look good - when you install the panel. (pin is higher or lower than original
)kind regards from France
Walter
edit: should have looked on the second page before posting, sorry !!
You can order them at your local DC-MB Dealer with the "HWA-Number" or directly in Germany at a AMG Shop/Dealer. You can send me as well a PM and I can forward you a good adress (AMG Centre).
Kind regards
Walter
There's apparent a separate AMG importer that my mate in sales knows and I asked him to get him to do something with the part #'s, ie go back to the factory with them...
" The dealer says he needs the chassis number and any other model numbers so that the factory can locate the part. At present they say with the existing number that there may be some numbers missing? I thought the Germans were smart!"
So what's the problem if 2 people here have ordered it. Do I have to go and supply the chassis # when this is a AMG non-specific SL55 part! WTF?
Anyone..
The part number is the correct one - be sure about this. AMG Affalterbach indicated this number on my invoice. I told you in a previous post, I can offer you a solution - but do not want to forward the adress of my dealer in here - cause it could cause misunderstanding (advertising)
kind regards
Walter
Ps.: you could order them directly, pay by CC - and shipping by mail.
kind regards
Walter
Walter thanks for confirming the part #. I really don't need an alternative solution, just a way of working out how my relative can order the part. Surely, if you can order it so easily in France, it should be as easy if not easier in German speaking Switzerland, with the dealer able to communicate directly with Munich for the item. Is there any other info that the dealer should be stating when asking for the part ie. Affalterbach. Perhaps they are not stating that it enough, despite my 2nd email which was forwarded that stated the following:
"It's an AMG series Mercedes part, they may have to look in the Mercedes AMG accessory catalog. It won't come up as general spare part, only the original ones will. If the Mercedes agent talks to Germany they will be able to use the part number. The exact German part description is : Part no: HWA1407600141 - "SICHERUNGSKNOPF" cost 35 Euros.
here's a photo of it so they know what it looks like."
This kind think really freaks me out when it should be so straight forward and you spoon feed the info to someone...
Don't know how Walter managed to order from them direct and pay by CC, they wouldn't deal with me at all, just pointed me at a dealer and so I went round in circles.
p/n 1407600341 -'Sperrknopf' is a OE 'LOCKING KNOB' from FRONT DOORS>CLOSING SYSTEM
kind regards
Walter
Thanks.
