SL55/63/65/R230 AMG: SL55 AMG Fuel Pump Enquiry
I’ve a question regarding my external fuel pump for my SL55…. A quick squirt of brake cleaner tells me fuel delivery is kaput.
I’ve heard that a firm called Maxgear who make a 43-0182 pump may fit.
Do any of you know if this Is this true?
I’ve got my eye on some extortionate Pierburg originals but their prices vary significantly… cheapest I’ve found is about £177… up to £395 for the same item….!!
I’ve ordered a new Bosch fuel filter already, and before I waste £50-£60 on a Maxgear pump (ie: getting the car to actually move), I thought I should canvas you all first.
Do any of you think it could be the Pierburg Regulator, mounted next to the pump…..? Part no: A230 545 1432… are these generally quite reliable?
Here is the Maxgear fuel pump adverised: 43-0182 MAXGEAR Fuel Pump for MERCEDES-BENZ,PUCH | eBay
I should add it’s been highly frustrating not having this machine in otherwise fully working order….turning over and firing….. as I’ve checked relay, fuse etc…..
Thank you, the educated and experienced, in advance.
Dave
What is odd is that this car has barely 65k miles on it and has been running perfectly up until I decided to fire it up from its persistently prolonged slumber........ the prolonged slumber might actually have been the issue - leaving complex things too long can introduce all manner of problems.......
Thankfully though, when a little brake cleaner is sprayed down the intake it fires right up. There is no fuel build up at all in the fuel rail after releasing the black cap and pressing the Schrader valve to test/ check.......
Anything else I should be checking?
......and prior to firing, your pump primes for approx 2 seconds, yes?
Slow progress, very..... and I hear you on the fuel pump longevity/ endurance... I've had a 2003 vw polo diesel for 5 years with 235k miles on the clock (40k-odd by me) and that fires like a champ - no issues whatsoever...... superb.
Thank you very much in advance.
I've got a very long test lead (well, part of: 2-core cable), so I can do precisely that. With the car quite low, and the car jack with another trolley jack when it does get lifted, I am literally taking my life in own hands whilst under it, I have to say it's not the experience I'll look forward to once I've got the crocodile clips here to make up this test lead to be honest..... they should be arriving tomorrow and I'm back into work tomorrow so with the cold, dark nights and finishing late every day...... I can tell this issue is going to prolong.....FFS.... irritating is a verifable understatement!
I'll report back what I deduce when I'm not working myself into an early grave! ;-O
Turns out it was just simply an inoperative pump, but was warned about the stale fuel in the tank, and to get plenty of fresh in it, tout suite.
As I dont drive the car much and would hate to think that stale fuel is in any way damaging a newly fitted fuel pump (and filter), I'm now searching for fuel stabilisers..........
Of course, open to tried and tested suggestions from those with experience on this matter.
Thank you!
