R230 SL55 AMG 2003
Old Nov 7, 2024 | 12:48 PM
MMENDEZ's Avatar
SL55 AMG
R230 SL55 AMG 2003
I had a problem with the central locking, checked fuses 9,26,38,41,57, and 71.
The PSE pump fuse 71(20A) was blown. I removed the pump, it had no corrosion, looked like new, and spun up fine.
So I reinstalled and changed the fuse to 25A after reading that it was more suitable due to the high start up draw.
Now all of a sudden the internal drivers door switches do not work. I have a Carsoft III but when running diagnostics it says the drivers door DCM (left Door Control Module) is not fitted.
I have disconnected and charged both batteries, checked all fuses, reconnected, and still nothing on the door works.
Any suggestions would be much appreciated.
Old Nov 7, 2024 | 06:40 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R230 AMG forum...
