SL55/63/65/R230 AMG: Audio Upgrades
Once again can I simply ask that next time you contribute to a forum with some advice on an install or an experience, you be a tad more specific.
Thanks,
Oz
The LC6 is just what's called for in this application, mind you JL is bringing out a similar device in June which should also be very good for these OEM integration problems. The only pitfall that the installer needs to be made aware of and one which none of the many people we spoke to indentified, is that the Command headunit has a reverse phase output in it's low end signal(thanks OEM Command maker!). This caused us some serious angst as it made us think quite understandably, that the ADS amp wasn't powerful enough to drive the Boston Z9's properly and the sound had serious lower mid range deficiencies. I was fortunate enough to be able to directly A/B compare mine with the sound of the Z9's in local Boston rep's own car, which is a big empty station wagon hard to deal with acoustically. I already knew there was a problem, but after hearing them again in the rep's fairly simple setup I knew exactly how much was missing from the sound. I had to laugh out loud when the rep made the remark to me that the sound in my car made it sound like a Bose system, which I said to him summed it up perfectly! We then wasted some serious time trying to figure it out and then tried Boston's largest amp, which naturally overcame the phase problem through sheer grunt. However, once this problem was indentified a few days ago we found that the ADS now drives the Z9's beautifully, as it should have in the first place. In the interim we had decided that we may need a digital EQ to counterract some lower mid range frequency deficiencies we thought were caused by the Command but really related to the whole phase problem. Fortunately, we didn't waste any time with the AudioControl DQT EQ before the phase problem was solved. After that though, we hooked up the DQT and had a go at fine tuning the system in conjunction with some laptop based RTA software. We were able to address a minor deficiency in the 600-900k range which did add a small but noticeable improvement in the expected lower mid ranges. At this stage I am thinking, even though it's not entirely necessary, to keep the DQT in the system and setup some custom EQ maps for myself.
Anyway, the end result is an enormous improvement over the drab stock sound quality or Bose system B.S. quality.
Hopefully a few out there will benefit from this info now that we have paved the way here to a degree.
And to SLVRSL55, I hope Isaac picked up on the phase situation, as it is in no way apparent when you hook up a OEM style plug to the Command as the phase is reversed internally in the Command unit itself. It was only by a process of elimination that my installers worked it out after significant time. So if he simply routed it to your amp that drives the sub, your sub is running out of phase and your mid range speakers may well be also, depending whether they use the stock reverse mounting or face forward (which is why the Command output is reverse phase in the first place) or if you didn't replace the mid-bass driver in the door (you didn't mention much about that).
No worries.
You might want to tell Isaac to spell check his email newsletters before sending them out too. He kindly put my installers on his email database (they are kind of bemused by that) and they showed me his email about his winning a 'Top Retialer' award recently.
