Corsa Extreme or race mufflers for SL55 R230 body
Happy Monday!
Does anyone have any links to Corsa mufflers that will fit or that can be modified to fit a 2006 SL55 - R230 body type? Currently, i have stock mufflers, but, i wanted to upgrade to some Corsa mufflers. It can be either cat back or just the muffler and preferebly with the 3 inch diameter piping.
If anyne has an experience or knowledge with this, please send me either part numbers or links.
thank you,
JT
thank you,
JT
Great news. I will be getting the MBH long tubes installed (from a local Mercedes shop with an expertise in all things AMG) tomorrow along with high-flow "green" primary cats and Fabspeed mini cats. Larger injectors will go in as well. After enjoying the car for a few more weekends, before she goes to hibernate for the winter, the next project will be whether to go with an 82mm or 92mm throttle body along with the prerequisite billet snout, larger Y pipe, etc. Lastly, I think a carbon fiber driveshaft will find a home under the car. Through some research and discovery, I've found that the Mustang and Challenger Corsa Extreme mufflers from 2018/ 2019 work well. It looks like the inlet and outlet pipes have to be on one side or the other for the ideal fit. It cannot be centered and one side or opposite side inlet and outlet. There will be some modification or much modification needed but it will def work.
here is one of the videos that were helpful.
Hope this helps other people to modify their rides.
