SL63 AMG & SL65 AMG (R231) 2012 to 2020 (in US launched as 2013 model) Facelift from 2017
Trunk opens but doesn't close
Old Nov 23, 2023 | 03:14 AM
thethunderbird's Avatar
2013 SL63 AMG
The automatic trunk closing on my 2013 SL63 has suddenly stopped working. The auto open works fine. If you close it manually, it will auto-latch. But the button on the trunk itself, nor the button on the fob, nor the button on the driver's door will close it. The latter two work to open the trunk, and the button on the trunk that closes the trunk and locks it will still lock the doors. When the trunk button is pressed, there is a noise that comes from the latch area of the trunk but nothing visibly happens.
Any ideas?
Old Feb 15, 2024 | 06:55 PM
2013 SL63 AMG
My mechanic has now spent hours trying to figure this out. He replaced the latch to no avail. Any thoughts?
Old Feb 15, 2024 | 10:51 PM
PeterUbers's Avatar
Any ideas?
how's your auxiliary battery? Replaced that recently?
also check the manual release pull ... it may be engaged; do you have a spare key in the trunk? Your motor may be shot.
https://mbworld.org/forums/w211-amg/...not-close.html
Old Jun 5, 2024 | 03:38 PM
2013 SL63 AMG
The issue ended up being split wires in the harness running up the side of the hinge.
