SLK/R170: Time for a change, New Gauge Faces installed
I got tired of the cream white faces in the instrument cluster so I changed mine to black...
Totally the same readings. Everything is in the same place. Readings on the speedo are in 10 mph increments instead of 20. Blinker and traction control symbols are hidden as well. The spacing is the same as the originals.
Replace just the faces. They are stuck to a clear piece of plastic that snaps in to the cluster. You have to pull the needles off so that the faces lift off. Also the dials for setting the time and reseting the trip odometer need to be pulled. Everything just snaps in to place. Once the new faces are in, then the needles are reinstalled and ajusted.
