SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Glove box light replacement?
Old Nov 21, 2005 | 10:18 PM
SlickSilverSLK's Avatar
1999 SLK 230
I cannot see how to remove the lens on the glove box light. Mine quit working and I want to replace the blub. Any ideas?
Thanks.
SlickSilverSLK
Old Nov 26, 2005 | 12:01 AM
70chevelle396's Avatar
2001 SLK 320 , 1970 Chevelle SS
The whole light just snaps in there. Just pry on it and it will come out.
Ken
Old Nov 27, 2005 | 11:29 PM
1999 SLK 230
More than a blub
Thanks for the quick reply. I removed it with no problem. The bulb and all internal parts are working. It seems to be activiated by the auto dim rearview mirror. I had the windshiled replaced. I wonder if they accidently damaged the wiring or mirror? Do you know of any test procedure for the auto dim mirror other than covering or shining a light on the photo-sensors?
Thanks.
Old Nov 28, 2005 | 11:17 AM
On mine I had to bend the spring on the switch a little bit. because the switch wouldn't move all the way. try pulling on the switch to see if the light comes on.
Ken
