SLK/R170: One Touch Top Operation
'03 ML500 & '11 R350
Probably, they are very similar. Does the Crossfire have a button that lights up when you activate the top and then the light shuts off when it's done? If so then it should work as it's just some relays. If you can pop the console off and look behind the switch, see if the wire colors are the same as DesignoSLK's instructions (if I remember it's brown for ground, pink/red for power, green/red for lamp power, white/violet and one more), then it's easy, if they are different you have to figure out which is ground, power, and lamp power, the other two don't matter as much as they are interchangeable. You can figure it out with a needle and meter.
By the way mines the gray one:
'99 SLK230
purdy car.. there's definately a way but you'll have to look around.
nah I haven't gotten it yet designo I'll probably be ordering it this week actually. 2 questions though.. does it put the top up? Does the top up procedure also put up the windows?
'00/'04 SLK230 Designo Copper, '17 Hyundai Santa Fe Sport Ultimate
BTW...04Fire...nice "aerial" pic.
If you want more functionality get the Bipe BVRC, it has one touch with remote control although it's slightly more expensive than 20 euros, close to 20 times more expensive.
