SLK/R170: Newbie SLK owner
Other than doing the normal maintenance, is there anything else I should look for in regards to known problems or preventative maint? The car has 40K miles on it. So far everything is working as expected, The top goes up and down smoothly and the heated seats can really get hot.
Steve
Due to the age of your car you can expect to replace a few items very soon. You have both a pre- and post- cat (catalytic converter) O2 sensor. When 1 goes bad, replace both. The Mass Air Flow (MAF) sensor will also go out soon. You can clean the sensor if your are careful, but it does wear out and will also need to be replaced.
The routine items such as hoses, belt, brake pads, spark plugs, air filters (both engine and cabin) are probably needed. Fuel filter should be replaced about now.
Changing the above items will keep you going for many, many more thousands of miles.
Happy driving!!!!
Shoot me an email when you get a chance. kevin.willard@nellis.af.mil
I appreciate the info and will make sure I check those things. Thanks for the good wishes. When the weather finally gets a little nicer here in NY, I will take some pics of the car.
Steve
