I bought this car a few months ago and I have notice that it leaking oil from the automatic transmission. I do no have a way measuring the remaining oil since it does not have a measuring "rod".
On the other hand I do not know where and how to add some.
Can anyone help on this?
Wattsaver
Wattsaver
This is common. You measure tranny oil by removing the red plug and using a service dipstick available at the dealer. Check out the post below, it maybe of help.
http://www.benzworld.org/forums/r170...t=transmission
Plus make one of these.
Measure at normal op temp in park, engine idling
Stick contacts bottom of sump and you measure up.
You can make one from a length of springy curtain rod and mark grads on. (53 to 63mm at 80c )
Bazzle
Bazzle
