SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: SLK dashboardlight replacement
Old Nov 7, 2007 | 05:36 PM
millster's Avatar
slk230
Hi,
I have a slk230 year 2000, i need to replace two bulbs in the dashboard, one is behind the petrol gauge the other behind the heater switch. Is this a task i could attempt myself, if so guidance or a link to instructions appreciated, if not i guess the labour costs will be too prohibitive and i'll have to live with it.
Cheers
Chris
Old Nov 7, 2007 | 07:24 PM
Squishy's Avatar
SLK
Do it yourself.
Click on the disassembly section.
http://www.buellwinkle.com/r170/
Old Nov 9, 2007 | 10:49 AM
millster's Avatar
slk230
Nice site, thank you very much
Old Nov 15, 2007 | 09:02 AM
E-Klasse's Avatar
W205 C300
Sounds like you need to pull the instrument cluster out and change the bulb if I am reading your post correctly. The cluster is tricky because you have to drop the lower half of the dash at the knee board and then take the face plate off that is over the cluster.
