SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Moisture in car
Old Feb 29, 2008 | 11:23 AM
doncale's Avatar
SLK230
Moisture in car
My SLK 230 will fog up bad inside the windows if I try to defrost the windsheild. I turn on recurlate and heat full.
What is causeing the moisture??????
Old Feb 29, 2008 | 11:41 AM
Taff's Avatar
slk
You have water getting in the cab, Clean your drains, to front to back,
rears are in the trunk near rear window corners, fronts under black bit the wipers pop up through, Use strimmer wire ( weed whacker ) and push it down untill it pops out of the bottom, you may have to pour some warm water down the pipe same time if its really blocked.
Old Feb 29, 2008 | 01:24 PM
doncale's Avatar
SLK230
Thanks, I'll try it this weekend.
Old Mar 1, 2008 | 12:32 AM
E-Klasse's Avatar
W205 C300
Plus, if your windows are fogging up, you don't want recirculated air from the inside of the car. You need fresh air from the outside. When the Defog setting is on, it actually uses the air conditioning to dry the air out. Make sure you are not in ECONONMY mode or the AC compressor will not turn on.
Old Mar 1, 2008 | 09:42 AM
Taff's Avatar
slk
Yes very true
I missed that bit of the post
Old Mar 2, 2008 | 11:04 AM
dumokie's Avatar
98 slk230, 98 ml230, #8 #24 and #17 Nascar race cars for promotional events see my home page.
Recirculate
Don't use Recirculate! Make sure your air conditioner works properly. In defrost mode the air is run through the A/C evaporator to dry, then through the heater core to heat it so you will have dry air hitting winshields. Change your cabin filter as well..
