SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Slk 230 P0410 secondary Air supply
Old Apr 2, 2008 | 08:44 PM
Astrok's Avatar
Can anyone tell me where the Air pump is located on this model
Old Apr 3, 2008 | 03:12 PM
bazzle's Avatar
Uses bypass from the supercharger when cold.
Get the MAF sensor cleaned 1st.
Bazzle
Old Apr 3, 2008 | 08:22 PM
Astrok's Avatar
can you clean the MAF with compressed air or do you need to do something different
Old Apr 4, 2008 | 10:41 AM
Buellwinkle's Avatar
Believe me when I say that they MAF gets all the kompressed air it needs when it's running. What you need is the good stuff, comes in a can, CRC MAF Sensor Cleaner, but it's going to cost you close to $6. Check Pep Boys or Autozone, they usually carry it.
Old Aug 12, 2012 | 08:46 PM
ghost2k's Avatar
e350
For me the P0410 was caused by a corroded air pump check valve.
My original valve part # is 0021402860. That was replaced by a newer 0021406860.
I found an older check valve 0001407860 for $20. Tried it out for several weeks and the P0410 is gone for now. Let's see how it goes. If the older valve 0021406860 doesn't work, I will go for the newer 0021406860.
To remove the valve, you will need a 27mm or 1-1/16" low profile wrench.
