SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: What after market anti-freeze mixes well with OEM fluid ?
Old Jul 8, 2008 | 08:51 PM
Thunderstrike's Avatar
SLK230
I have 1998 SLK230, 4 cyl, and was wondering if there's a special anti-freeze I need to get that will mix well with OEM fluid.
Thanks for the reply in advance.
Old Jul 10, 2008 | 04:40 PM
bazzle's Avatar
IMO its never a good idea to mix AF.
Ive seen them turn to gell.
For the cost its best to completely drain, flush with water and refill with MB AF.
Some brands do state suitable for MB.
Your call there.
Bazzle
Old Jul 10, 2008 | 05:17 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Ditto to bazzle. Depending on what you have in there now, you might be able to use one of the Zerex fluids that meets MB specs. If you don't know, change it all and use OEM MB. It doesn't cost that much even at a dealer. FWIW, on my car MB recommends a complete coolant change every 3 years.
Old Jul 11, 2008 | 02:53 AM
H-townbenzoboy's Avatar
1981 300SD TurboDiesel, 1982 300D TurboDiesel
Zerex G-04 is a direct replacement for MB fluid and will mix with MB fluid without trouble.
