SLK/R170: SLK200 Performance ?
I was wondering what i could do to the engine to improve it's performance.
Also if anyone had any suggestions on how to make my car look better....plz feel free to reply. I just got a bunch of money and i dont know what to spend it on for my car.
Thanx!!!
If you wanna sink money into exterior esthetics, you could upgrade to facelift looks by purchasing the parts from your MB dealer (is DIY job), or shop at Lorinser, Brabus, FAB design, Inden design, to name a few. I personally like the FAB parts best.
You can also slab on up to 19" wheels but ride quality and speed/acceleration will suffer, especially if you don't beef up the engine.
I have a '99 SLK (Silver) and I dont think its a kompressor.....
Thanx!!!
G'luck
The Väth solution is by far the best, and those who have done it, have posted enthusiastic comments (185 hp without, 205 hp with Supersprint header/muffler and new airbox).
Where do you get your info from ???? and why do you write
it doesn't come non supercharged with stiffer block and stronger pistons.
The non and supercharged 111 4 cyl. engines, are exactly the same.
The supercharged have lower CR, but no parts are made stronger or different in any way.
KLEEMANN had a 4 cyl. program of superchargers, but stopped producing it 6-8 month ago.
Stay with facts and don't write BS, some might belive you are right.
Do you call your self " MASTERMIND"
"Noise has been reduced by ribbed reinforcement of the crankcase."
"The pistons are made from heat-resistant alloy with higher copper and nickel content, and the piston crowns have been reinforced."
This info applies specifically to the pre-facelift SLK.
If you do, my advice for all readers is to stay away from Kleemann as they're oblivious to basic knowledge or/and mislead their customers.
What they forgot to write in that book, was the 111 engine have had many face lifts since introduction in the W 202 body in 1993.
I have in person made over 500 supercharger installs, 50 enlarged dispalcement engines, SLK 230's where the OE Eaton
SC and intercooler has been trashed and replaced with quality stuff where out put has been in the 300 HP range on the 111 engine, so I have seen more than 1 from the inside.
The facelifts they have done to the SC 111, will also be found in the NA 111, but why should they point that out in the book.
If you want to see for your self, then take 2 engines apart and look
by writing a SLK 200 from 1999 and the poor customer don't have to worry, because nobody tried to sell him anything.
If you go back to the first 111 engines, then they didn't have oil jets under the pistons, this also came later, the top shape of the piston has changed ect.ect.
