SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: headlight
Old May 12, 2009 | 06:22 PM
racall's Avatar
headlight
Can i remove the headlight without removeing the bumper??I just managed to get a pair of OEM xenons.Car is a
R170 year 2000
Old May 13, 2009 | 03:43 AM
BJ's SLK320's Avatar
2001 SLK320
Yes, although the process is easiest if you remove the grill. If you want, I can give you step by step directions to how to remove everything.
Just let me know.
Old May 13, 2009 | 07:06 AM
racall's Avatar
Yes please
Yes that would be helpfull
I just got a pair of OEM xenons i would like to fit.There is an extra plug on them for self levelling can i just leave it blank??
Old May 13, 2009 | 10:52 PM
2001 SLK320
Sorry for the slow reply....I was looking for a website I once saw that had really good pictures of how to remove headlights, but I can't seem to find it.
For removing headlights, step 1: Remove the grill:
1. Check out the pictures 491, 492, & 493 and remove all 6 screws (circled in red) that attach the top of the grill to the car. Make of note of where each screw came from, I had two long screws and 4 short ones. I'm wasn't careful, so I don't know exactly where they came from, but I put the two long ones in the top corners.
2. Please note that the grill bottom is actually hooked underneath the front bumper-cover, so you will need to be careful as you slowly finesse it out.
3. Now with the grill removed, it will be much easier to remove the headlight and install the new one.
4. Remove the side marker light to expose the third screw for the headlight. In order to do this, you need to lightly pull on the beige round tab. See blue circle in picture 496. Make sure and pull towards the outside of the car and be gentle, I have heard several stories of people breaking theirs. Picture 501 shows the removed marker light with the beige tab.
Attached Thumbnails headlight-dsc03491.jpg   headlight-dsc03492.jpg   headlight-dsc03493.jpg   headlight-dsc03496.jpg   headlight-dsc03501.jpg
Old May 13, 2009 | 11:02 PM
2001 SLK320
5. Next, you need to remove the three screws that hold the headlight in place. Look at the yellow circles in pictures 494, 495, & 503.
6. Once you have all three off, you should be able to easily pull the entire headlight assembly forward. From there, you need to disconnect the headlight and parking light wires. I was able to pry mine off with my fingers, but you might need a small flathead screwdriver.
7. From here you simply follow the same instructions to get the other headlight off, then reverse the order to install your new headlights. Because you got OEMs, I think everything should be plug & play.
8. As far as the self leveling plug goes, unfortunately, you are on your own. I have no experience with those. IMO, I think you are okay with simply not plugging them, but I am not sure how they effect the aiming of the headlights.
Good luck with the install. Make sure and take pictures to post of the before, during install and the final product.
Feel free to PM me or reply to this thread if you run across any issues....I'm never too far away from my computer!
Attached Thumbnails headlight-dsc03494.jpg   headlight-dsc03495.jpg   headlight-dsc03503.jpg
Old May 17, 2009 | 06:48 PM
320 dreamer's Avatar
2003 porsche 996 turbo
on mine theres a hole on top of the side marker. inset screwdriver and push forward. side marker pops put. remove the screws holding headlight in. no need to remove grille.
Old May 18, 2009 | 05:38 AM
racall's Avatar
Xenons
I fitted the xenons yesterday and are up and running fine.
For information i left the levelling plug dissconected and didnt even have to get then enabled on star
Just need these black plastic wheel arch trims now.any one got a part number.its a japanese import into the UK
Attached Thumbnails headlight-br-cwnwcgk-kgrhgookk-ejllmzickbj92b5jey-_12.jpg
