SLK/R170: Trans service???
TIA,
Peter Voss
'99 SLK 230 sport
'01 ML 430
'00 Audi S4
"Lifetime fluid" is marketing garbage. I'm sure the fluid will last the warranty period very easily, but I find it hard to believe that changing the fluid won't significantly prolong the life of the transmisison beyond that.
I'm probably going to change the fluid myself right after the warranty expires, assuming I keep the car that long.
I found some info on how to do it yourself over at mercedesshop.com.
A bolt under the transmission oil pan can drain the fluid.
Response is quicker after changing the fluid, you may feel it.
