SLK/R170: Help!2001 SLK 320
Good luck!
Ben
On another note, this might be the perfect excuse to go and get an aftermarket radio. I've had a pioneer unit in mine since about a month after I bought it, and I love that I don't have to get in the trunk to put a CD in. It is also a good way to add a built in GPS system (assuming you have the funds).
Also, one other radio thought (and then I promise I will leave you alone
) is that, if you have the little radio bump on the trunk lid, then you can actually use that as a GPS antenna for a built in unit. The wire for that terminates under the driver's seat.Okay, thats all the wisdom I have for now. Have a good evening!
Ben
https://www.slkworld.com/performance...de-slk230.html
