SLK/R170: Radiator Fluid Level Light
Thanks in advance...
took it to the dealer. They said that based on the sensor desing (float, at least on a 2002) if the fluid is not topped up to the top, the float moves around and gets stuck in a position that falsely indicates low levels. They simply added more coolant to force the float to the top at all times and the problem disappeared. That was over 8 months ago, no problems since. Hope tis helps!
