SLK/R170: p0440
If I never let the fuel go below 1/2 tank I would never know there was a problem with it. Any ideas on where to start checking? I've already got a new gas cap on there.
Start by checking your purge valve.The lines to it and clean it.
Diy write up in the diy section on w210 forum www.benzworld.org
If that purge valve is clean and ticking away like it should and the cel does not clear then you need to inspect failed or leaking tubes to your charcoal canister.
Start with the purge valve
Also don't top off your tank when filling up
just shut off at the first click of the gas pump
