SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: I need to see pics of an OEM SLK 230 manual shift knob, how does it fit?
Old May 30, 2003 | 01:37 AM
PrimalX's Avatar
Does anyone have pictures of a manual SLK230 shift knob off of the car? How does it attach to the linkage?
Thanks!
Old May 30, 2003 | 12:46 PM
Brian_R170's Avatar
'02 SLK32 AMG
Sorry, I don't have pics, but I know how the knob attaches.
The knob has a "twist lock" at the bottom. You have to pull the boot all the way up to see it. All you do is turn that lock 1/4 turn counterclockwise and you can pull the knob off the shift lever shaft.
If I recall correctly, there's a small groove in the top of the shift lever shaft, and when you turn the twist lock, it squeezes a plastic bump inside of the knob into the groove on the shaft.
