SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: SLK230 idles up then down over/over - help
Old Jan 21, 2012 | 10:52 PM
sealluke's Avatar
slk 230
My 1999 SLK 230 is acting strange... Turn key It starts then idles up then down, up/down over and over but here's where it gets stange.... When I give it gas the car won't repond -still the up and down idle - when I pop the hood and manually twist the idle regulator thats gas cable connects to - I still get nothing. The car will drive slowly in drive during it's idiol cycling. Why won't it repond to the gas pedal??? A bad sensor??? It starts, idoils eractly but no further RPM's from the gas pedal.... Thank's for your help!!!
Old Jan 22, 2012 | 10:02 AM
livefreeordie's Avatar
2002 slk230K 1986 560sl
Do a search on how to clean the MAF, also search for the K40, its a known issue with the Pre face lift models.
Old Jan 22, 2012 | 04:28 PM
sealluke's Avatar
slk 230
reply
I've replaced the K40 box and MAF 3 years ago and that made a difference back then - Do you think it could be a TPS (throttle position sensor)? part number W0133-1786802
