SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: MAF
Old Feb 25, 2012 | 05:56 PM
wgben22's Avatar
'00 slk 230k
MAF
I need a new MAF. My question is: Can I buy a Bosch insert from a place like Germanstar or Amazon or do I need to buy the whole unit? It seems to me that the sensor, the part that works, just slips into the plastic housing. Why can't I use the old housing? It would save money. '00 slk230 99k
Old Dec 9, 2012 | 09:18 AM
wood123firebird's Avatar
1998 slk 230
MAF
I am new to the forum and just got myself a used slk 230 that had a maf problem. I fixed it by cleaning with MAF cleaning spray and lightly rubbing with a folded pipe cleaner. there is a shiny side plate that the air flow past on the sensor that needs to be really clean. after cleaning look at it with a jewlers eye loop to look for streaks. you should be able to cean to a mirror like finish with no streaks. then disconnect the battery to clear the memory in the cars computer and reinstall. After I did this the car is running like a champ!
Old Jan 16, 2013 | 09:56 AM
morpheusRO's Avatar
w204
Or if it's broken, just buy a new one! You will definetly see the difference!
Good Luck!
