SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: slk 230 Battery Charging Light on
Old May 26, 2012 | 03:37 AM
JOHNMCGLOUGH's Avatar
1998 SLK 230
Hello All,
I have a 1998 slk230. I had a new battery fitted and since then the Charging light is on all the time.
I have tested the Alternator and found that there is no power to the Field terminal. I connected a wire from +terminal to the field terminal and the charging light goes out.I am assuming the alternator is fine because I drove to the garage to have new battery fitted and all was well.
Does anyone have a link to a wiring diagram of the charging system?
Could the K56 Relay be at fault?
Thanks J.Mc
