SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: big brake problem
Old Aug 5, 2003 | 10:38 PM
manliz's Avatar
slk230
Question big brake problem
just put on set of brembo big brakes have 19" rims w/35 offset rims are hitting the caliper will try 10mm center spacer also i have h&r sport spring should i use the largest rubber spacer on the spring so the wheel clears the well without rubbing the fender, please need help
Old Aug 6, 2003 | 12:34 AM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
I think it will help but you might fix one problem and create another problem because you push the wheel farther out with 10 mm spacer.
That's something you will know after install the 10 mm spacer. Good luck.
Old Aug 6, 2003 | 01:17 AM
Brian_R170's Avatar
'02 SLK32 AMG
Re: big brake problem
Originally posted by manliz
just put on set of brembo big brakes have 19" rims w/35 offset rims are hitting the caliper will try 10mm center spacer.
I assume they're rubbing on the spokes. How close is it. Can you get by with a smaller spacer (if a smaller spacer exists)? What wheels are you using?
A 10mm spacer is going to change your effective offset from 35mm to 25mm. With that offset, I think they're going to rub unless the tires are narrower than 225s. The spring pad isn't going to make much difference. Even if you raise the fender a bit, they'll still rub over bumps and during moderate to heavy cornering.
Old Aug 6, 2003 | 02:51 AM
Clk&Slk's Avatar
The next smaller would be 5 mm. I do not recommend 5 mm spacer because it not "hub-cemetric" (no lip). It will cause vibration due to the wheel is not center onto the hub. You can alway order custom spacer.
Old Aug 6, 2003 | 11:35 AM
Brian_R170's Avatar
'02 SLK32 AMG
I agree.
Hmmmm. CLK&SLK. Is that you, Linh?
