SLK/R170: re: rear brake light holders
'98 SLK 230
Hi,
Has anyone had problems changing rear brake lights?
Mine seem to be almost impossible to take out. I managed to get one off but then I dropped the harness thing.. so now it is sitting at the bottom of my rear guard somewhere.. I hope it doesn't rattle bcoz I can't reach it... I'll probably have to get a whole new harness for it.
andrew
andrew
'98 SLK 230
well I was actually trying to change my brake light bulb, but coudln't twist the harness out? it seemed to be stuck, eventually I managed to twist the bugger out with some unbelievable force, only to drop it down between the panels.
This morning, I had to take all the plastic moulding out of the boot and fish it out with a long bendy stick with a magnet on the end of it.
but now its all good.. brake light has been replaced
1 Post
'02 SLK32 AMG
Oh, you mean the bulb socket. I thought you meant the wiring harness.
The '98-'00 SLKs have a habit of forming corrosion on the contacts between the socket and the housing AND between the bulb and the socket. I would bet that's why it was so difficult to remove. Sometimes, the corrosion will get so bad that the entire housing must be replaced. I recommend you pull all of the sockets from both brake light housings and put a small dab of grease on each of the contact points.
SLK 230 Limited Edition
After two times of replacing my brake light, I've grown accustomed to doing it. I will admit that it was a beeyatch at first but then I got used to it.
1998 SLK 230
Does anyone know how to take out the tail light assembly?
I have the upper break light lamp that is out on my tail light assembly and I have replaced the lamp as well as the lamp holder to no avail. Does anyone know how much effort it will take to remove the tail light to inspect it for rust or if needs be replacement? At some point I would like to have both tail lights working again..
1994 s320
Removal of lens assy
There are 3 nuts (8mm I think) that must be removed to remove the lens assy. The contact plates pit where the socket connectors hit. You can try to clean this but more often than not the whole assy needs to be replaced. Good luck with your project.
