SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: 1999 R170 came with only one key, need another...
Old Nov 5, 2013 | 12:06 AM
r170's Avatar
r170 slk
because I am on the water and the probability of losing it overboard is not zero. The dealer here states a charge of several hundred dollars. Is there a USA or UK dealer who can get me one at a more reasonable cost (one that will start the engine)? If so, contact info please.
Or even a reliable non-dealer supplier?
Thanks.
Old Nov 5, 2013 | 02:19 PM
CarolinaBluetec's Avatar
2008 E320 Bluetec (until 11/14), 2001 SLK 320, 2004 Volvo V70, 1972 MGB, 2013 E350
The key must be purchased from a dealer. They will require proof of ownership. Then the key must be programmed at dealer. Shop around at dealers within driving range. Some dealers have quoted as low as $250 including programming
Old Nov 5, 2013 | 04:26 PM
r170's Avatar
r170 slk
Only one dealer in this remote area. Quote is US$420. Insane.
Old Nov 6, 2013 | 08:06 AM
Some dealers will let you fax the VIN number and they will order the key. Then you must bring in the car when you get the key. It is a security thing.
Old Nov 11, 2013 | 03:19 PM
r170's Avatar
r170 slk
Checked with Burlington, Ontario dealer and you are correct in all respects. Got another quote from a different dealer in NZ: $625 for the key, $140 for programming. Ripoff. Have attached my key to a float, bulky but it won't sink and disappear if I drop it.
