SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Recirculate jammed on
Old Dec 4, 2003 | 04:56 AM
JimboUK's Avatar
SLK 230
The re-circ function of the heater/ac unit in my 98 SLK is stuck permanently on. I've had the car in at the dealers and they've checked the control unit which is fine.
I have the feeling that it's just physically jammed. How easy would it be to get to the unit and check it myself?
Old Dec 4, 2003 | 07:18 PM
luke's Avatar
'03 slk32 AMG
I had the same problem about a year ago. The faulty parts do not trip error codes in the computer, but I insisted that the tech femove the fresh air filter and watch the flap. When it didn't budge by pressing the button, he became a believer. The parts replaced under warranty were:
210-830-07-72 Temperature Sensor
202-800-18-75 Vacuum Element
202-800-13-76 Vacuum Control
My car fogged up to the point that I had to drive with the windows open in frigid weather. The heated seats helped.
It took several days to repair and they had to dismantle the dash, which rattled a bit for several days after until all was settled again. Good Luck.
Old Dec 5, 2003 | 10:31 AM
JimboUK's Avatar
SLK 230
I have the same problem now it's getting a bit cold outside - except I dont have heated seats!
Just a couple more questions ...
Was yours a 98 model too?
How did you get access to the filter in order to see the flap?
Thanks!!
Old Dec 10, 2003 | 06:02 PM
luke's Avatar
'03 slk32 AMG
Mine is a '99 sport, but the internal systems are all the same. The fresh air filter is located under the glovebox and above the passenger floor area. You get to it from below. I seem to remember that there are pictures on PerioKid's site: www.slk32.com Give it a look.
