SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Need help with leak.
Old Dec 13, 2003 | 12:50 PM
donovanl's Avatar
SLK230
My car leaks when it rains hard. The water collects on the passenger side floor board only. I removed the plastic cover that is behind the glove compartment above the passenger floor board and discovered more moisture. I removed the cover of a plastic box on the right hand side (that was behind the other cover until I removed it) that was secured with two white slide latches. This is where the water is coming from.
Any help would be appreciated.
Thanks.
