SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Clutch Help
Old Jan 14, 2004 | 08:30 AM
steve1173's Avatar
Slk 230 & CLK500
Clutch Help
Have a 2003 SLK230 with 6 speed. Have less then 2000 miles on it & noticed that the clutch sometimes came up slowly. Was looking under the dash to see if the mats or carpet could be doing it & noticed the spring on the clutch pedal looked stretched. Took the picture to the dealer to show them while my other MB in for service. They checked with many techs & none were sure as they said they don't see many manual ones. One even said maybe it is a variable spring. The lead tech took the picture with him to check it. I attached the picture for you to look at. Any ideas if it is normal. Tried attching with no luck so hopefully can describe. The lowest to links are wide apart & the whole spring does not move on depressing the pedal only those 2.
