Heater fails to work when engine idles
On my 2000 SLK230,when the motor is at 180C (normal operating temperature) and when I turn on the heater to maximum heat (red zone), maximum blower speed (5) for the driver and passenger sides, plus vents on the floor and dash are wide open and it is 32 F outside (night) I feel cold air coming out from all vents. If, however, I speed the engine up to 3,000 RPM's the air quickly gets hot from the vents and floor. When the engine returns to an RPM at or below 1200 RPMs for a few moments, the hot air slowly return to cold again. To stay warm, I have drive around in lower gears to keep the RPM's above 2,400 to heat the cabin and keep it warm. What is causing this? What must I do to fix this? I purchased an OEM dual electric regulator which regulates the passenger and driver side of the cab for heat control. I have not installed it yet. I took the current regulator apart and found no corruption in it and the valves worked up and down with gentle touch easily as they should. I replaced and checked the radiator, coolant and heater hoses. No bulges, lumps or leaks. I put on a new water pump... works fine for engine temperature regulation. I flushed the entire cooling system installed the correct coolant mixed 50.50 with distilled water for the SLK 230 (per specs). I replaced all of the hoses that deal with water deliver including the heater core hose. I purged air from all hoses by squeezing them b into a water container to see the bubbles of air purged form them (thus eliminating air bubbles in the cooling system). I bought a new radiator cap. I installed new pully belts. I replaced the cabin air filter. I checked the control cables on the dash were working properly (they are). Radiator fluid is filled to between the full and add marks on the overflow tank. I then I prayed! Still has the same problem. I have concluded that I have to back flush the heater core and install the new regulator. If that doesn't work... any other ideas? Please advise.
Reason: Corrections
