SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Has anyone eliminated ABS on R170?
Old Oct 15, 2017 | 10:28 PM
rhd280's Avatar
w460 1982 280ge
My saga of fault codes and lights continues, but I thought I would ask...
In-so-far as my 2001 SLK is on a snow/ice-free island with a maximum speed of 50KPH (30mph), very few roads and limited distance, I really do not need ABS. In fact, with my Toyota I cannot think of a single time it kicked in.
Is it possible to disconnect ABS from the electronic monitoring system?
Old Nov 2, 2017 | 11:47 AM
loggato's Avatar
1999 SLK 5.5L 6-speed, 1993 300 SE
have you tried unplugging the ABS module to see if any of the other systems freaked out? It's the big unit under your brake booster that has all the brake lines screwed into it.
Old Nov 13, 2017 | 04:18 PM
slk230red's Avatar
'93 190E 2.3, '01 SLK230, '71 Corvette LS5 Roadster
Yes, the easiest way is to disconnect the power going to the ABS Pump. I had to do this when my Module was defective the ABS Pump would continue to run even with the engine off and key removed. I disconnected the power lead at the terminal block next to the duo valve on the passenger side. I found a used Module, installed it and the problem was resolved.
While I drove the car with the power disconnected to the ABS pump, the brakes worked fine and I couldn't tell any difference under normal driving.
