SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: slk spuddering
Old Jun 20, 2004 | 07:21 PM
snglbrd's Avatar
slk 230
slk spuddering
the last couple of days my car --slk 230 98' starts to sputter and has a small back fire when I floor the gas pedle. I noticed a loss in power also. I changed the spark plugs around 7months ago. I just put fuel injector cleaner in today. any ideas on what it could be? thanks
Old Jun 23, 2004 | 09:04 PM
RedSLKChic's Avatar
You might have a clog in the fuel filter or line. That happened to one of my cars because I let the tank get so low so often, the filter started picking up little pieces of crap in the bottom of the tank.
Old Apr 12, 2007 | 05:31 PM
deancrook's Avatar
water in engine bay
I also had the same issue as you. I also put injector cleaner in the fuel tank. But I think my issue was water somewhere in the engine area. The engine bay had been power washed by the guy I bought it off and think he jet washed it a bit too close. All is good now.
Old Apr 15, 2007 | 04:27 PM
bazzle's Avatar
Remove maf sensor, spray liberally with maf cleaner and air dry.
Bazzle
Old Apr 19, 2007 | 07:45 PM
bfitch's Avatar
I had essentially the exact same syptoms, cleaned the MAF and it worked better for a time, but about 10,000 miles later I ended up having to replace it (dealership price around $550 installed).
