SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: 01 320 slk engine turns over right after that it stops
Old May 28, 2019 | 04:59 PM
Carly Carroll's Avatar
2001 320 slk
Lost electronic key and spare key turns ignition on but does not turn over. Remove cable fr battery tap 3 times on battery and it turns over but will not run. Any ideas?
This is spare key I lost the electronic key.
Old May 28, 2019 | 07:55 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R170 forum...
Old Aug 14, 2019 | 12:39 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Not seeing any reply here. Did you get this sorted?
The key should start the car as it turns over so I suspect 1 of 2 things.
These cars need a great battery. Not a decent one, A great battery
The second thing I suspect is the crankshaft position sensor. They fail with some regularity and typically open so there is no signal to the computer as to where the crank is and it cannot decide where to deliver fuel and spark so it does nothing. It could be something else I suppose but ...!
