SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Problems with gas
Old Jul 2, 2004 | 12:44 PM
FernandoSLK's Avatar
SLK 230 K 1998
Problems with gas
Hello to everybody!
I´m having problems with my 98 230 SLK, when I don´t use it for 2 weeks or so, when I start the engine, the car spills gasoline by the "carbon filter"?, for a couple of minutes. Then it stops leaking and the car runs perfect, no leakage at all, even if I go to the gas station and fill it up, it doesn´t spill anymore. If I use my car everyday it doesn´t happen anymore.
The guy in the shop told me that it could be that gasoline in the tank after a couple of weeks not using the car creates lots of gases, so when starting up the gasoline bomb creates a lot of pressure and gases have to scape someway amd that´s why it spills gasoline.
Has anybody had this problem before? Thank you all and sorry for my bad english.
Old Jul 8, 2004 | 01:13 PM
pjfslk's Avatar
SLK230
Doesn't sound too good!! I also have a '98230K but even when it is parked for extended periods there isn't any gasoline vapor smell. It could be that the evaporative emission canister was overflowed and contaminated. That's why it is so important not to overfill the fuel tank.
For safety sake have it professionally checked, gasoline vapor is very explosive!
Old Jul 23, 2004 | 04:34 PM
SLK 230 K 1998
Where is that canister located? Maybe changing it could be the solution?
Thank you very much for your help.
